Trying to generate an exterior ray-trace view at night
ADallas
I added some lights to the front rooms, viewed the house from outside in Physically Based (Ray Trace) mode and everything looked fine. Then I chose 3D > Lighting > Toggle Sunlight and I expected to see a dark scene with light pouring out of the windows. Instead I get black with little white circles where the lights are visible through the windows. I haven't tried this before, so I apologize in advance if it's a dumb question (I did try to search for a previous answer), or if Chief just can't generate views like that.
If you want to create a nighttime scene, you should start by changing the color of the sunlight (as I did with the early evening scene below) . Your background makes a difference as well. It would help to post your plan.
Thanks! The Generated Sky stars are very interesting, but my view is still mostly black. I can't seem to turn the sun dark enough or the moon light enough to see my house in the dark/at dusk. I changed the moon luminance from 2500 to 250,000 (it limited me to 100,000) but there was still no difference in the rendering.
