Cadwork22 Posted March 19 Share Posted March 19 I need to punch a round hole in my patio roof for a firepit. Does anyone know how this is done. Link to comment Share on other sites More sharing options...
DBCooper Posted March 19 Share Posted March 19 Draw a circle on the roof. Use convert curve to polyline. Use convert poly to make it a roof hole. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 19 Author Share Posted March 19 This is created when I convert curve to pline. This is created when I convert to pline, What settings should I input, so far nothing is happening. Thanks, Michael Link to comment Share on other sites More sharing options...
Solution DBCooper Posted March 19 Solution Share Posted March 19 When you use the "convert curve to polyline", a dialog should pop up that lets you choose the number of sides. Depending on how smooth you want it, you could use something like 24 or 36 and it should look pretty good. When you use the "convert polyline" tool, you will want to choose "hole in roof". When you click ok, the roof hole specification dialog should open. I had better luck when I used "plumb sides" instead of "square sides". Link to comment Share on other sites More sharing options...
Cadwork22 Posted March 19 Author Share Posted March 19 Nice thanks Link to comment Share on other sites More sharing options...
