cbucks Posted March 15, 2024 Share Posted March 15, 2024 I have a plan with multiple structures, beyond selecting each room individual there a way to select an entire floor for one structure? Link to comment Share on other sites More sharing options...
DBCooper Posted March 15, 2024 Share Posted March 15, 2024 What are you trying to change? Depending on what you are trying to do, I might make some different suggestions. Here are some things that might work though: - Select all (ctrl-a) will select everything on the screen that is visible and not locked. - Marquee select similar will let you select things that are similar to whatever you first selected. - Match properties will let you select other objects with the same properties you picked and then you can even apply those properties to other objects if you want. - Edit area will let you select things in a rectangle or polyline shape and edit them as a group. 1 Link to comment Share on other sites More sharing options...
