Angular Dimension
Cadwork22
Go to solution Solved by Chopsaw,
I've gone through the chief library and experimented with the program settings and still not finding the answer I am looking for.
See attached, I've created an A Frame structure, and would like to adjust the angles to an equilateral in an elevation view.   Is this possible.  I found the angular dimension tool, but it doesn't produce any text.
