Chucky843 Posted March 2, 2015 Share Posted March 2, 2015 Hi there, Im working with X6 Pro, Below is a picture of the project im working on. Im having problems with the roof for a 1 1/2 story house. What is the best way to go about what im tring to accomplish. I want to have as much space as possible for the 2nd floor this house will be built on a stem wall with a crawspace 3ft to bottem of floor joists. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 2, 2015 Share Posted March 2, 2015 did you check out the KnowledgeBase (KB) ? there is a tutorial there for this type of home (CapeCod) http://www.chiefarchitect.com/support/article/KB-00653/34/Chief-Architect/Roofs/Building-a-Roof-that-Bears-on-the-First-Floor-Walls-of-a-Two-Story-Structure.html there is this one too http://www.homedesignersoftware.com/support/article/KB-00358/52/Home-Designer/Roofs/Automatically-Building-a-One-and-a-Half-Story-Roof.html Link to comment Share on other sites More sharing options...
Chucky843 Posted March 2, 2015 Author Share Posted March 2, 2015 I read both of the Tuts you recommended, which i have previously read. This is how far i got. Now how would i make it so the door and bathtub on the second floor are not clipped by the roof above it? Link to comment Share on other sites More sharing options...
AriseDesign Posted March 2, 2015 Share Posted March 2, 2015 So there would be a roof over the bathroom? What I am asking is if the bathroom will protrude the roof? Link to comment Share on other sites More sharing options...
Chucky843 Posted March 2, 2015 Author Share Posted March 2, 2015 I wouldn't mind if the roof protruded the roof as long as there was sufficient head room on the second floor. ted.zip Link to comment Share on other sites More sharing options...
AriseDesign Posted March 2, 2015 Share Posted March 2, 2015 it says your plan has no date, make sure you close the plan before zipping it Link to comment Share on other sites More sharing options...
NRST8TRKR Posted March 2, 2015 Share Posted March 2, 2015 Raise the main roof on the House. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 2, 2015 Share Posted March 2, 2015 Raise the main roof on the House. From your images your house has a 0" 2nd floor ? Raise it to 36" though 42" or higher is better to allow furniture placement etc. if you only need/want extra room height in the bathroom then add a Dormer over the Bathroom only , though in that case I'd make it 10-12' long instead and give that front bedroom more space and extra Windows allowing cross ventilation. Link to comment Share on other sites More sharing options...
RevolutionDB Posted March 3, 2015 Share Posted March 3, 2015 Draw a section of your house, and measure and locate a line that is 84" (7 feet) above the finished floor. Our local codes require that at least 50% of a half-story room (like your second floor) be 7'-0" or above in order to be a legal bedroom/bathroom/living space. This will enable you to have a bathroom with enough height for a shower, and doors that aren't clipped. You can do one or all of the following to increase the height of the second floor ceiling: raise the pitch of your roof (10:12, 12:12, or more); build knee walls on the second floor (as suggested earlier) to raise the starting point of the roof, and/or increase the width of the house. It looks like your design has a narrow corridor down the center where you could stand upright. The knee walls are very low, looks like +/- 3'-0", so a person could not stand there. Hope this helps! Link to comment Share on other sites More sharing options...
