RL-inc Posted March 1, 2024 Share Posted March 1, 2024 Probably a basic function but I have run a few searches and not seeing anything that addressed my particular need here. I am working with 3d solids to create a metal base shoe for a beam stair stringer. As I insert holes into the solid, I find myself needing to adjust their size- location - etc..... I can select the 3d solid of course, but can't select the hole itself? any suggestions are appreciated. Link to comment Share on other sites More sharing options...
imodel Posted March 1, 2024 Share Posted March 1, 2024 Did you try using Tab Key? Link to comment Share on other sites More sharing options...
RL-inc Posted March 1, 2024 Author Share Posted March 1, 2024 Tab to try and move from selecting the solid to the hole? Just tried it and it reacts similar to the next command- does not recognize the hole. Link to comment Share on other sites More sharing options...
RL-inc Posted March 1, 2024 Author Share Posted March 1, 2024 Thanks Eric- I don't think was in tight enough to grab the hole - all good. Link to comment Share on other sites More sharing options...
