How to relabel a 3D solid, give it a name and a symbol category name.
Chief42020
Go to solution Solved by tundra_dweller,
I create a 3D solid, lets say a bollard. I convert it to a 3D solid. I want to label it as "Footings, Post".
I open the "3D solid specification" box. Go to "Label" and go to "Label Layer" and select "Use Custom Layer". Click the drop down list and put this bollard in "Footings, Post" and press "OK".
Then I go to "Layer Display Options", select the layer I want to display and I uncheck "Fittings, Post" so it doesn't show in the plan. Its still there.
Also, when I go back to click on the "bollard" again, it shows at the top of the box as a "3D solid specification".
I want to create a 3D solid, give it a name in the "Layer sets" (Footings, Post) and be able to check it or uncheck so it will show or not show up in the layer set I am in.
I've tried the the little chair, "Convert to symbol" and changed the symbol name and category, still with no luck. Still pops up as a 3D solid.
What am I doing wrong.
Build: 24.3.0.84 macOS Intel
X-14
