Chief42020 Posted February 26, 2024 Share Posted February 26, 2024 I create a 3D solid, lets say a bollard. I convert it to a 3D solid. I want to label it as "Footings, Post". I open the "3D solid specification" box. Go to "Label" and go to "Label Layer" and select "Use Custom Layer". Click the drop down list and put this bollard in "Footings, Post" and press "OK". Then I go to "Layer Display Options", select the layer I want to display and I uncheck "Fittings, Post" so it doesn't show in the plan. Its still there. Also, when I go back to click on the "bollard" again, it shows at the top of the box as a "3D solid specification". I want to create a 3D solid, give it a name in the "Layer sets" (Footings, Post) and be able to check it or uncheck so it will show or not show up in the layer set I am in. I've tried the the little chair, "Convert to symbol" and changed the symbol name and category, still with no luck. Still pops up as a 3D solid. What am I doing wrong. Build: 24.3.0.84 macOS Intel X-14 Link to comment Share on other sites More sharing options...
Solution tundra_dweller Posted February 26, 2024 Solution Share Posted February 26, 2024 I think you'll also want to change the 3D solid's layer to "Footings, Post" in the Line Style dialogue. Link to comment Share on other sites More sharing options...
glennw Posted February 26, 2024 Share Posted February 26, 2024 I think you may find your object on the 3D Solids layer. The label will probably be on the Footings, Post layer Link to comment Share on other sites More sharing options...
Chief42020 Posted February 27, 2024 Author Share Posted February 27, 2024 Not sure how that makes any sense putting it in the "Line Style", but oh well, it works. Greatly appreciated!! Thanks Brett! Link to comment Share on other sites More sharing options...
