Where do I go to change default layout size to 13x19 vs Arch D?
cbucks
If you are creating a title block for the size of you new set up, that is done on sheet 0. They are cad lines and text. I save layers per layout in the same file. Generally one for landscape ArchD, 11x17 landscape and portrait.
