5Design Posted February 21, 2024 Share Posted February 21, 2024 Just at a loss here. I can go through and add each of the headers / beams as I need to, just a pain. It has something to do with the wall type as when I changed the wall with the 2 car garage to a 6" wall, it doesn't do it. It's not doing the roof framing right, either. But that's just a Chief thing (I'm guessing). And it disappeared the brick on the model for whatever reason. IDK. Sawmill DR Framing.zip Sawmill DR Framing.zip Link to comment Share on other sites More sharing options...
DBCooper Posted February 21, 2024 Share Posted February 21, 2024 I didn't download your plan but I would check to see if you accidently marked the brick as "framing". 1 Link to comment Share on other sites More sharing options...
mLongChief Posted February 22, 2024 Share Posted February 22, 2024 17 hours ago, 5Design said: Just at a loss here. I can go through and add each of the headers / beams as I need to, just a pain. It has something to do with the wall type as when I changed the wall with the 2 car garage to a 6" wall, it doesn't do it. Looks like the brick layer for that wall has been set to be a framing layer. Open up that particular wall for specification and check its wall type. The Brick-4 wall type its using has the brick layer marked to be framing. Unchecking the Framing checkbox for that layer should resolve that issue. 17 hours ago, 5Design said: It's not doing the roof framing right, either. But that's just a Chief thing (I'm guessing). I'm assuming the issue with the roof framing is that ridge board sticking through the bottom of the roof plane? Seeing as you're using manual roof planes, you could reduce the size of the ridge's depth in the lower roof planes so they'll fit within the roof cavity. It's probably sticking out since this lower roof plane is mostly in the overhang portion, so it's not properly trimming the ridge. It does look like a bug, so I'd report that to our technical support team. Link to comment Share on other sites More sharing options...
5Design Posted February 22, 2024 Author Share Posted February 22, 2024 42 minutes ago, mLongChief said: Looks like the brick layer for that wall has been set to be a framing layer. Open up that particular wall for specification and check its wall type. The Brick-4 wall type its using has the brick layer marked to be framing. Unchecking the Framing checkbox for that layer should resolve that issue. I'm assuming the issue with the roof framing is that ridge board sticking through the bottom of the roof plane? Seeing as you're using manual roof planes, you could reduce the size of the ridge's depth in the lower roof planes so they'll fit within the roof cavity. It's probably sticking out since this lower roof plane is mostly in the overhang portion, so it's not properly trimming the ridge. It does look like a bug, so I'd report that to our technical support team. Nah, was talking about adding the sub-fascia in between the rafters for the different pitches, but thanks! Link to comment Share on other sites More sharing options...
5Design Posted February 22, 2024 Author Share Posted February 22, 2024 17 hours ago, DBCooper said: I didn't download your plan but I would check to see if you accidently marked the brick as "framing". Yah, not sure how I did that, but that was it. Thanks! Link to comment Share on other sites More sharing options...
