Need some help with "cheek walls"?
RicatRandM
Go to solution Solved by robdyck,
I alluded to this in an earlier post. This seems to be a limitation of Chief or it may have something to do with how you got to this point . Even if you manually edit the wall polyline, you'll still have ceiling surfaces 'missing'. Chief simply won't join those ceiling surfaces. You may need to resort to ceiling planes, or use 3d solid to fill in the gaps.
  • Solution
Here I've manually edited the wall polyline (something I hate doing but when all else fails...) and added a ceiling plane for the steeper ceiling. You can derive the correct elevations for your ceiling plane from a cross section view.
