RicatRandM Posted February 20, 2024 Share Posted February 20, 2024 If you look at the cheek walls on second floor from the interior in 3d...I can't seem to get them correct? Also, if you look at the back elevation, I have a couple of misc. lines in the facia I can get rid of either? Any suggestions would be greatly appreciated... Thanks. Ric x15 CAPE WILD LIFE DO IT ALL OVER 1d.plan Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 I alluded to this in an earlier post. This seems to be a limitation of Chief or it may have something to do with how you got to this point . Even if you manually edit the wall polyline, you'll still have ceiling surfaces 'missing'. Chief simply won't join those ceiling surfaces. You may need to resort to ceiling planes, or use 3d solid to fill in the gaps. Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2024 Share Posted February 20, 2024 The fascia lines are due to those edges of the roof having more than one line segment. You simply need to clean up the roof shape and the unwanted lines will disappear. fascialines.mp4 Link to comment Share on other sites More sharing options...
Solution robdyck Posted February 20, 2024 Solution Share Posted February 20, 2024 Here I've manually edited the wall polyline (something I hate doing but when all else fails...) and added a ceiling plane for the steeper ceiling. You can derive the correct elevations for your ceiling plane from a cross section view. Link to comment Share on other sites More sharing options...
RicatRandM Posted February 20, 2024 Author Share Posted February 20, 2024 Great! Will give it a whirl... Thanks very much! Ric 1 Link to comment Share on other sites More sharing options...
