5FT-20Designs Posted February 15, 2024 Share Posted February 15, 2024 I want to color highlight, say LVLs for example, on my framing plan. Is there a way to assign a solid color fill style to a layer so everything on that layer is colored in all views? Know I can open the item to assign the color or assign a colored material so it shows in 3D views. Thanks, Keith Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted February 15, 2024 Solution Share Posted February 15, 2024 1 hour ago, 5FT-20Designs said: I want to color highlight, say LVLs for example, on my framing plan. Is there a way to assign a solid color fill style to a layer so everything on that layer is colored in all views? Know I can open the item to assign the color or assign a colored material so it shows in 3D views. Thanks, Keith No...a 3d view is going to apply a material to your framing member, so you would need a material with the color you want, but there is no way to assign a material based on the layer of the object it is being applied to. Link to comment Share on other sites More sharing options...
