Need some help?
RicatRandM
Hey Ric. Here's a few items to clean up.
  • The cheek walls are on the Attic level. Cut/paste them down to the 2nd floor. Check default top & bottom height.
  • There are 2 roof planes on each side of the building for the 4:12 roof. Just use one. You can join them or just extend the larger one to the match the outline of the smaller one, then delete the smaller one.
  • The 28:12 roof has a hole in it.  Turn on the Roofs, Openings layer and delete the hole. Then break the roof plane so it is U-shaped. Drag the edges to the outside of the exterior walls and the roof will snap to the correct location.
This will correct most things.
This will leave you with a hole inside where the cheek wall meets the upper roof. There would be several ways to clean this up, but before you work on that, it would be best to make sure the roof structure has all the correct elevations.
image.thumb.png.06cffd2ab28a636e7385c31ac067efb3.pngimage.thumb.png.7ef855b6bebe59257cb13038f914595a.pngimage.thumb.png.265875c00aa0cbcc849416c41e7b0298.png
