Need some help?
RicatRandM
Hey Ric. Here's a few items to clean up.
  • The cheek walls are on the Attic level. Cut/paste them down to the 2nd floor. Check default top & bottom height.
  • There are 2 roof planes on each side of the building for the 4:12 roof. Just use one. You can join them or just extend the larger one to the match the outline of the smaller one, then delete the smaller one.
  • The 28:12 roof has a hole in it.  Turn on the Roofs, Openings layer and delete the hole. Then break the roof plane so it is U-shaped. Drag the edges to the outside of the exterior walls and the roof will snap to the correct location.
This will correct most things.
