With stairs and auto stairwell is there a check to build a wall around stairwell or do you have to do this manually?
cbucks
It will...just make your default stair railing wall a "solid" wall before you build the opening. Not sure that is worth the effort...you can just group select the walls, open them for specification and change the railing wall type to "solid". Same result.
