cbucks Posted February 14 Share Posted February 14 With stairs and auto stairwell is there a check to build a wall around stairwell or do you have to do this manually? Link to comment Share on other sites More sharing options...
SNestor Posted February 14 Share Posted February 14 It will...just make your default stair railing wall a "solid" wall before you build the opening. Not sure that is worth the effort...you can just group select the walls, open them for specification and change the railing wall type to "solid". Same result. Link to comment Share on other sites More sharing options...
