HannahMcNee Posted February 14 Share Posted February 14 Does anyone know how to create moldings on beams on a vaulted ceiling? I've tried adding the molding to the room, or creating a cabinet to follow the roofline, or adding moldings to the soffit but nothing has worked. Any input is helpful! I've attached two images. One with the vaulted ceiling, and one of the adjacent flat-roofed dining room. I'm trying to achieve a similar look to the dining room. Link to comment Share on other sites More sharing options...
SNestor Posted February 14 Share Posted February 14 You will have to use a 3D molding poly line drawn using a back clipped section camera. Of course...depending on what style molding you want to use...such as a crown molding...will not join in the corners properly because of the intersection angle. Time consuming...and somewhat difficult task. Link to comment Share on other sites More sharing options...
rgardner Posted February 14 Share Posted February 14 2 hours ago, HannahMcNee said: Does anyone know how to create moldings on beams on a vaulted ceiling? I've tried adding the molding to the room, or creating a cabinet to follow the roofline, or adding moldings to the soffit but nothing has worked. Any input is helpful! I've attached two images. One with the vaulted ceiling, and one of the adjacent flat-roofed dining room. I'm trying to achieve a similar look to the dining room. Use soffits for the beams and set as sloped to follow ceilings. 1 Link to comment Share on other sites More sharing options...
