LotzCC Posted February 9, 2024 Share Posted February 9, 2024 I can't find the door I want in any of the catalogs, but see one that is close. Is it possible to make a copy of a door and then modify and save it to my user catalog? Link to comment Share on other sites More sharing options...
imodel Posted February 9, 2024 Share Posted February 9, 2024 @LotzCCNo not really. Good news is doors are pretty easy to make. Draw them with slabs, etc, in plan view and convert to a door symbol. Link to comment Share on other sites More sharing options...
LotzCC Posted February 9, 2024 Author Share Posted February 9, 2024 See attached screenshot of the garage doors in my model and a photo of the existing garage doors and my CA file. I used the modern steel door with windows but don't see a way to mirror the door like other objects. I want the windThompson 1.1.planows to the outside on both right and left doors. Also want to modify the size of the windows. Also want to add windows to top of the center door. Thompson 1.1.plan Link to comment Share on other sites More sharing options...
Kenoeightspot Posted February 9, 2024 Share Posted February 9, 2024 Convert to symbol - then show advance options then reflect geometry then use replace from user lib. Link to comment Share on other sites More sharing options...
imodel Posted February 9, 2024 Share Posted February 9, 2024 William has the solution to reverse the one in the Library. If you want one that isn't in the library start with this. Edit to your desired variant. Go to 3D view and: Use tools, symbol, convert to symbol Check advanced Symbol category is door Rotate 90 in the X Set smoothing to 1 Name symbol Options select garage Add stretch planes in X Pull door panel from the library and test it. Mirror and repeat. For the big door create the whole door and after placing set no of panels to 1. Modern Steel.plan 1 Link to comment Share on other sites More sharing options...
Ringos Posted June 10, 2025 Share Posted June 10, 2025 On 2/9/2024 at 3:37 PM, Kenoeightspot said: Convert to symbol - then show advance options then reflect geometry then use replace from user lib. Sounds like you know what to do. But just a couple more minutes of your time with more detailed instructions would help the people coming behind you know what you are talking about. Link to comment Share on other sites More sharing options...
