cbucks Posted January 29, 2024 Share Posted January 29, 2024 Good day is there an easy way in CA to show the 12" walk line on stairs? Concentric 12" walk line on winders? Link to comment Share on other sites More sharing options...
DBCooper Posted January 29, 2024 Share Posted January 29, 2024 Are your winders done with landings or curved stair sections? The short answer is yes, as long as you are using curved stair sections (look in the stair dialog). If you are using landings, the walk line doesn't show on landings so you will have to draw it yourself. Link to comment Share on other sites More sharing options...
