GrizzlyBear Posted January 28, 2024 Share Posted January 28, 2024 What is happening here with my corners and attic wall here? I thought that it may have been my wall types but I tried a few different combinations to no avail. Also tried a few different ceiling settings for the porches and carport.Bouknight_rev2.plan.zip Link to comment Share on other sites More sharing options...
Solution scottharris Posted January 28, 2024 Solution Share Posted January 28, 2024 Sometimes at 3-way wall intersections, the wall layers compete. The ‘edit wall layer intersections’ tool or marking one of the exterior walls as ‘through at end or start’ can fix it – not always. In this case, you can use a wall type of ‘partition’ for your invisible wall; it does not cut the layers of opposing walls (like glass shower walls). I made a copy of your “Lean to Wall”, marked it as a partition, and it looks to work. Try it out. 1 Link to comment Share on other sites More sharing options...
GrizzlyBear Posted January 28, 2024 Author Share Posted January 28, 2024 Worked like a charm Scott! Thanks! In the future I'll have to explore the "edit wall layer intersections" tool you mentioned. Any idea why I can't seem to generate that attic wall under the carport area? I know my wall heights at this intersection are wonky, but if I could just get that attic wall to generate I think that I can live with it for now. Link to comment Share on other sites More sharing options...
GrizzlyBear Posted January 28, 2024 Author Share Posted January 28, 2024 Figured the attic wall part out. I had "flat ceiling over this room" checked in the Room Specifications. 1 Link to comment Share on other sites More sharing options...
