UPGRADED VERSIONS & OLDER VERSION LIBRARIES DISAPPEARED
Designer_Maddee
I have been operating on x14. Yesterday I finally upgraded to x15 but have files I still need to operate in x14 until my coworkers upgrade. I logged in to work on them and all of my libraries including the core ones have disappeared. When I do "library" - "Install Core Content". It says they are up to date but nothing shows up in my library. When I attempt to import "user catalog" from my files I get the following message "The library "/var/folders/y7/r35qpkxx7ts27x6bkm49q5fc0000gn/T/ChiefTemp_1/User_Library.calib" has an invalid version number and cannot be read. Changes made to the library will not be saved during this session."
Any advice on how I fix this?
Sounds like an issue for tech support. They do have an article with information on manually installing libraries if it fails, you might check it out and see if you can delete and reinstall them.
https://www.chiefarchitect.com/support/article/KB-02899/manually-installing-core-catalogs-for-chief-architect-premier.html
That will only cover the Core catalogs though.
