Designer_Maddee Posted January 17, 2024 Share Posted January 17, 2024 I have been operating on x14. Yesterday I finally upgraded to x15 but have files I still need to operate in x14 until my coworkers upgrade. I logged in to work on them and all of my libraries including the core ones have disappeared. When I do "library" - "Install Core Content". It says they are up to date but nothing shows up in my library. When I attempt to import "user catalog" from my files I get the following message "The library "/var/folders/y7/r35qpkxx7ts27x6bkm49q5fc0000gn/T/ChiefTemp_1/User_Library.calib" has an invalid version number and cannot be read. Changes made to the library will not be saved during this session." Any advice on how I fix this? Link to comment Share on other sites More sharing options...
TeaTime Posted January 17, 2024 Share Posted January 17, 2024 Sounds like an issue for tech support. They do have an article with information on manually installing libraries if it fails, you might check it out and see if you can delete and reinstall them. https://www.chiefarchitect.com/support/article/KB-02899/manually-installing-core-catalogs-for-chief-architect-premier.html That will only cover the Core catalogs though. Link to comment Share on other sites More sharing options...
