3dsDan Posted January 8, 2024 Share Posted January 8, 2024 does anyone know what the portion under the door is and how to get rid of it or fix it. As highlighted in the attached image. I have extended the wall below floor but the portion below the door shows up like that. how do I ensure the door is not affected by this. thanks in advance Link to comment Share on other sites More sharing options...
rgardner Posted January 8, 2024 Share Posted January 8, 2024 Very hard to tell in this picture but a few things come to mind as possibility. Best would be to include your plan in this post after closing chief first. 1.) Did you manually adjust the wall below or the wall this door is in place? Select both walls and in the structures panel of the wall DBX make sure that default wall top and bottom height check boxes are selected. 2.) Is the door sitting on the subfloor like it should be (at 0 elevation)? If it is raised up then the apron might be set to this and that might be what you are seeing. Hard to tell from the picture but in the door casing panel of the door dbx midway to the bottom is the option to use the sill apron. Link to comment Share on other sites More sharing options...
