livninavl Posted January 5, 2024 Share Posted January 5, 2024 When I use the CA Build Framing function it keeps adding these beams under the interior walls and for the life of me I can not find out why. This how it should look But when I let CA build framing this is what I get This is the floor above Sorry I cannot upload my design as it exceeds the maximum file size. Anyone have any ideas? Brian I am using X15 Link to comment Share on other sites More sharing options...
robdyck Posted January 5, 2024 Share Posted January 5, 2024 Post your plan using Google Drive / Dropbox. Link to comment Share on other sites More sharing options...
JLU_Design Posted January 5, 2024 Share Posted January 5, 2024 Under Wall Specification / Structure Uncheck insert floor framing below. Link to comment Share on other sites More sharing options...
livninavl Posted January 5, 2024 Author Share Posted January 5, 2024 Good idea: https://drive.google.com/file/d/185wrSNrr75mIxQKTbJv-dd9wOkIAkpsU/view?usp=sharing Link to comment Share on other sites More sharing options...
livninavl Posted January 5, 2024 Author Share Posted January 5, 2024 JLU... unfortunately that did not work Link to comment Share on other sites More sharing options...
Solution robdyck Posted January 5, 2024 Solution Share Posted January 5, 2024 Your rooms should ALL use the default floor structure (which should be defined). This will allow the floor framing to build uniformly. Currently the framing is being separated because there are different types. Select all rooms on each floor and ensure Floor Structure - Default is checked. Open Default Settings and edit the Floor/ Ceiling Platform defaults. Ensure the framing layer is set to trusses (or whatever you prefer). Rebuild floor framing. 1 Link to comment Share on other sites More sharing options...
livninavl Posted January 5, 2024 Author Share Posted January 5, 2024 The default under structure was not checked everywhere.... Thank you for all the answers. 1 Link to comment Share on other sites More sharing options...
