Manual Switch Options
Jonathan3891
Go to solution Solved by Renerabbitt,
  • Solution
18 minutes ago, Jonathan3891 said:
I'm trying to manually change this switch to a 3 way but the symbol is not updating.
Is there a way to connect electrical components from one floor to another? For instance I have a light switch at both the top and bottom of the stairs.
just place a symbol that is a 3way from your library,otherwise you need to edit the CAD block and add your annotation for the symbol you are trying to modify.
Use CAD Lines set to the electrical connections layer to depict a connection between floors
