Dims not showing on island (wall elevation view)?
5Design
Go to solution Solved by MarkMc,
  • Solution
1 hour ago, 5Design said:
Any ideas (first snip)?
You are using a wall elevation. There is a wall where you get dimensions but an invisible wall behind the island.
Change to a backclipped section.
image.thumb.png.7e116375c378b8b5b523feff72297412.pngimage.thumb.png.f8e50f931f67ff46ffcceb82f24d58af.png
OR setup a default set to do cabinet elevations manually (that's what I use instead of auto dims but you need several for different sets conditions so you can just click and drag)
Snip 2- could copy one camera in place, move forward, change technique to line drawing no squiggles or such and gray lines. Stack the two in layout.
Thank you, sir!
