Benny_G Posted December 17, 2023 Share Posted December 17, 2023 Dear Chief Architect community, I am currently working on a reform of a house from the ninety's. The building has a kind of small tower with a broken arch window on all four sides. Above the window there is a niche an in this niche there is millwork done with the same bricks as the interior and exterior sash of this window. Whether the millwork is in the niche of just the millwork or the niche is not that much important to me. But does somebody have an idea how to create the decorative part above the window? Your help is very much appreciated. Kind regards, Benny Benny Gasser Mobile: +41/79 749 36 49, benny.gasser@gasser-architects.ch Chief Architect X15, MacBookPro, 2 TB, 16 GB RAM Link to comment Share on other sites More sharing options...
kmccluskey Posted December 21, 2023 Share Posted December 21, 2023 Type in valance in the library and place it above the window. Paint it the color of the stone. You can use the dropper to select the color and then select the valance when placed. When first placed it will likely be sitting on the ground level, adjust as needed. Link to comment Share on other sites More sharing options...
Benny_G Posted February 6, 2024 Author Share Posted February 6, 2024 Thanks a lot for the help. The solution you suggested worked really well. Benny Link to comment Share on other sites More sharing options...
SNestor Posted February 6, 2024 Share Posted February 6, 2024 A wall material region would also work...and probably faster also. 1 Link to comment Share on other sites More sharing options...
