How to Change the Depth of a Wall Corner Cabinet.
GlennX5L
I'm using Home Designer Pro 2024 and I'm trying to change the depth of a corner wall cabinet. I'm able to change the right and left side widths to 27", but there is not an option to change the depth. I have a design where the cabinet heights and depths are staggered. The taller 42" cabinets have a depth of 16", and the 36" cabinets have a depth of 13".
1591664946_WallCabinetSpecification.thumb.jpg.a862900dabe9de197e9a2124722758e4.jpg532178096_WallCabinetImage.thumb.jpg.fc5cf34d25d9029ac8d5a1613c61e928.jpg
I have no problem changing the depth of a standard wall cabinet...
I have 2020 Designs kitchen software that is advanced, and I'm able to do the staggered depths and heights. Here's a shot from the 2020 software of what I'm trying to accomplish in HD Pro...
I'm just trying to see what is possible in the HD Pro 2024 software. Has anyone done something like this???
Thanks,
Glenn
On 12/1/2023 at 11:06 AM, DBCooper said:
Try placing a normal cabinet, change the depth to 13", and then change it to a corner cabinet using the cabinet dialog.
Well Sir...what you suggested worked. I grabbed a standard wall cabinet, increased the depth to 16", and then changed it to a corner cabinet. I also increased the left and right side widths to 27". This is the staggered height and depth I was trying to achieve using this software. Now I just have to change the cabinets to a beaded inset style.
THANKS!!!!!
. 2019250006_16inDeepCornerCabinet.thumb.jpg.7c5e73737702b81eaab9c972e6c061ef.jpg
