Revolve Command Not Working for Me
KnotSquare
I have always found Revolve a bit squirrelly to use.
Eric gave you some good advice but there is another way to  easily do your "plate" if you want to do it separately.
Draw a Cylinder.
Convert it to a 3D  Solid.
Select it and then select Fillet Lines from the Edit toolbar. (change the fillet radius as needed)
Select the faces to fillet (you will get a preview as you move the mouse around).
