binkpear Posted October 20, 2023 Share Posted October 20, 2023 Hello all! I have a finished set of plans for a friend that was for a 3 storey 5 plex. He now plans on building another building exactly as the 5 plex except it will now be a 4 plex (17' less than the 5 plex). Is there a simple way to somehow delete one of the middle 3 storey 17' suites to get what he needs easily? I wanted to check with the forum before I start it from scratch again... Thanks for your time! Link to comment Share on other sites More sharing options...
Solution robdyck Posted October 20, 2023 Solution Share Posted October 20, 2023 Yes, using the Edit Area (All Floors) tool you can neatly cut a portion out and move the left or right remaining section the appropriate amount. A little trial and error along with the undo key and you'll have it figured out in no time! Link to comment Share on other sites More sharing options...
binkpear Posted October 21, 2023 Author Share Posted October 21, 2023 Thanks Robert! That did the trick, easy peasy! 1 Link to comment Share on other sites More sharing options...
