Bay roof
Benzarch
Are you using auto or manual bay window and roof planes?
Does the bay have short return walls either side or there only 3 walls forming the bay?
I assume the side walls are at 45deg?
Do the roofs have to meet at the same apex point?
Just as a starting point tip though - you can use a negative number for the Curved Roof>Radius To Framing Top to achieve the concave curve.
Here is a quick example:
  • Like 2
  • 4 weeks later...
Neat trick to get the under slung effect Glenn.
