carowe Posted October 18, 2023 Share Posted October 18, 2023 I have a client who would like to get a jpg of a proposed renovation with enough resolution to blow it up to 32" x 24" poster. I have played with the resolution and nothing changes regarding the file size on the saved jpg. Is there something I'm missing? Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted October 18, 2023 Solution Share Posted October 18, 2023 27 minutes ago, carowe said: I have a client who would like to get a jpg of a proposed renovation with enough resolution to blow it up to 32" x 24" poster. I have played with the resolution and nothing changes regarding the file size on the saved jpg. Is there something I'm missing? Set your screen to a shape roughly equal to your target dimensions, go to File > Export > Export Picture, and click "Units", type in the dimension you want, keep "Retain Aspect Ratio" checked, then enter something like 200 DPI. That will produce a pretty high resolution picture, about 3.6 MB. Some clipping may be required to change it to the exact dimensions, unless you can set that ratio up before saving. Link to comment Share on other sites More sharing options...
