capitaldesigns Posted October 13, 2023 Share Posted October 13, 2023 I am trying to setup dimension defaults going from a scale of 1"=10" to 1"=150'. I am having a problem setting the line separation and 1st Line Offsets. Chief will not let me increase past 16'-8". At 1"=150' that puts the 1st Line Offset to close to the building. I need the offset to be closer to 55' at this scale. Is there a way to increase the offset ? Thanks, Mike Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 13, 2023 Share Posted October 13, 2023 54 minutes ago, capitaldesigns said: At 1"=150' that puts the 1st Line Offset to close to the building. I need the offset to be closer to 55' at this scale. Is there a way to increase the offset ? Just curious why you would be using such a scale ? Why not draw your dimensions manually for that view...assuming it is a site plan. Otherwise use match lines at a lower scale Link to comment Share on other sites More sharing options...
