Dimension Default Settings
capitaldesigns
I am trying to setup dimension defaults going from a scale of 1"=10" to 1"=150'.
I am having a problem setting the line separation and 1st Line Offsets.
Chief will not let me increase past 16'-8".
At 1"=150' that puts the 1st Line Offset to close to the building. I need the offset to be closer to 55' at this scale.
Is there a way to increase the offset ?
Thanks,
Mike
Just curious why you would be using such a scale ? Why not draw your dimensions manually for that view...assuming it is a site plan.
Otherwise use match lines at a lower scale
