Window creation.
ChiefPat971
To me that window looks like three windows mulled together.  Two double hung windows and one fixed glass with two lites and a little solid filler piece.   Hopefully Google will help you translate as it did for me. :)
I did not actually mull the window since I had no idea what your exact requirements were but I did remove the sill from the upper window.
I think there are settings for how windows mull but I am by no means an expert at that.
Is your window separation in Defaults 0  ?   if it is, have a play with the setting in the Window , under Options called Mullion Depth, it accepts both positive and negative numbers.
image.thumb.png.0f553fa78a18a72ecd201c588dfdbfd5.png    image.thumb.png.c6810748896d6adec1f62cc5f8155ed5.png
You also need to adjust the Casing so it overlaps the Frame, ( per the real world) I can see it is set to 0 as well
image.thumb.png.b1ba5d57bf9592abacfb2a7614b95f65.png  image.thumb.png.b21190634172cf132bc7f34d6f41b952.png
You should really put questions over in the Q+A Forum rather that in te Seeking forum which is for Paid Help....
Mick.
  • 2 weeks later...
