blueriver Posted October 5, 2023 Share Posted October 5, 2023 Hello Can someone offer advice on how to properly arch a door? I have chosen "round arch" but it only arches the frame on the inside. On the exterior both to door and the frame are arched but the image on the inside only shows the frame arched. I've tried changing the door but it doesn't help. Picture attached. Thanks in advance! Link to comment Share on other sites More sharing options...
blueriver Posted October 5, 2023 Author Share Posted October 5, 2023 Thanks Eric! I saw another very similar post and it said to change it to a glass door - i was changing it from the library of doors and not the door type drop down and taht wasn't working. Changing the actual door type worked, thank you! Link to comment Share on other sites More sharing options...
DBCooper Posted October 5, 2023 Share Posted October 5, 2023 Here is the short answer for the next person that does a search and finds this thread: If your "door style" is set to "library", your door panel is just a symbol and it won't be shaped to fill the opening the way you want. Just choose one of the other door styles, such as "panel" or "glass panel", and the program will build it properly. 2 Link to comment Share on other sites More sharing options...
