Using Chief for a yardstick
Rich_Winsor
So you’re measuring an as built for an addition and there is a large feature
(tree, structure, utility pole etc.) on the lot and you would like to get a good
quesstimate of its size. Here is a quick and easy way using only a stick or
pole of known length and your cell phone:
Measure the length of the pole and then stand it up beside the feature you
want to measure.
Back up a ways to reduce distortion and take a photo.
Import your photo into a Chief plan and measure the length of the pole in the
plan. If the pole is the correct length (run out and buy a Lotto ticket because
it’s your lucky day) but it most likely will measure shorter than its actual length.
Divide the known length of the pole by the measured length in the plan. This
will give you the resize factor you will need to enlarge the photo.
Select the photo in the plan and use the Transform/Replicate to enlarge the
photo by the resize factor you calculated.
The photo is now to scale and you can pull any dimensions you may want
from the plan.
In this example we wanted to get a good ballpark figure for the height of some
redwood trees on the property. I had a 17 foot piece of pvc pipe which we stood
up for the photo.
if you have some of the more advanced, cheaper, laser measurer, you can stand 20' away, take a horizontal measurement, and point to the top of the tree and take that measurement, and then the device will calculate it for you.
...but the above method usually only works at night/dusk when you can see the laser
