CedarCreek Posted September 25, 2023 Share Posted September 25, 2023 How do you make an applied side panel full length? If you ender a larger value in the Item Height field, CA sets it back to the default size. Link to comment Share on other sites More sharing options...
DrawingABlank Posted September 25, 2023 Share Posted September 25, 2023 You can try this. Change the box construction to traditional overlay. Then go to Front / side/ back. Select the side panel The alter the specs for appliance / door / drawer. Change the bottom to the desired height. (toe kick) Reduce the other overlaps to match back up to your full overlay spec. There may be better way. Link to comment Share on other sites More sharing options...
DBCooper Posted September 25, 2023 Share Posted September 25, 2023 Instead of doing a custom face for the side and making the item an "applied panel", just make the whole side "auto paneled". Then you can just use the panel settings on the "accessories" page to set the panel style and use "full size panel" and "extend to bottom". 1 Link to comment Share on other sites More sharing options...
