How To: Full Length Applied - Side Panel
CedarCreek
You can try this. Change the box construction to traditional overlay. Then go to Front / side/ back. Select the side panel The alter the specs for appliance / door / drawer. Change the bottom to the desired height. (toe kick) Reduce the other overlaps to match back up to your full overlay spec.
There may be better way.
1380924531_appliancedrawerdoorspecs.thumb.jpg.3aeb1b3b272f4318504b19b3102155be.jpg2020542760_Spectheoverlap.thumb.jpg.425c7a71d5e997970ad6bdb164f3e011.jpg
Instead of doing a custom face for the side and making the item an "applied panel", just make the whole side "auto paneled".  Then you can just use the panel settings on the "accessories" page to set the panel style and use "full size panel" and "extend to bottom".
