JEFFRO56 Posted September 23, 2023 Share Posted September 23, 2023 Greetings all! Been using Chief for a little less than a year. 25 years with AutoCad and 10 years with Revit before Chief. Question: is there anyway for chief to make arrow heads that look like this? Thanks! Architectural-Graphics-detail-line-weight.pdf Link to comment Share on other sites More sharing options...
glennw Posted September 23, 2023 Share Posted September 23, 2023 4 hours ago, Chopsaw said: Perhaps put in a request for the option to use a cad block from the library that has unlimited options. Chopsaw, We can already do this .......and then save it as part of a default set. This is just a filled polygon, saved to the library and used as an arrow. This then means that it is the default for each arrow drawn. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted September 23, 2023 Share Posted September 23, 2023 43 minutes ago, glennw said: Chopsaw, We can already do this Ooopsy..... Thanks Glenn I missed that one. Link to comment Share on other sites More sharing options...
JEFFRO56 Posted September 24, 2023 Author Share Posted September 24, 2023 Thanks Glenn, can you explain how to do this? Tried making a filled box but it won't let me make it into a block. Link to comment Share on other sites More sharing options...
glennw Posted September 24, 2023 Share Posted September 24, 2023 Select the cad filled box and then shift select it again, convert to block and save to library. Link to comment Share on other sites More sharing options...
JEFFRO56 Posted September 24, 2023 Author Share Posted September 24, 2023 Awesome! Worked! Thank you Glenn! Link to comment Share on other sites More sharing options...
