ElkRivers Posted September 19, 2023 Share Posted September 19, 2023 Does anyone have experience with this, or know how to fix it? Maybe it's two separate issues. My stone on the main floor works correctly, showing that the edge of the brick wraps around the corner. Upstairs it isn't modeling correctly. Then on the 2nd image I am showing that there is also a 9" pony wall with stone that matches the stone cladding on the foundation. The pony wall stone also has a problem intersecting with the main wall stone. Any thoughts or ideas? Thanks! Karen Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 19, 2023 Share Posted September 19, 2023 Issue 1. Edit Wall Layer Intersection tool in the Edit toolbar. Select the wall in plan view, click the tool and manipulate the intersection: Issue 2. I saw it suggested here to try making the other wall a pony wall also, with the same elevation settings. Link to comment Share on other sites More sharing options...
ElkRivers Posted September 19, 2023 Author Share Posted September 19, 2023 Thanks to both of you for your help! I was able to get it almost perfect by playing with the wall layer intersection tool, and by making the tall wall also be a pony wall. I still haven't been able to get the water table to model correctly. To answer your question, Solver, I am not exactly sure what the builder is going to do there. I had planned to model it with the water table just ending flush with the front of the tall stone wall. Link to comment Share on other sites More sharing options...
