Walls at higher ceiling
winterdd
Hey guys, here is a new one for me. All ceiling heights in the home are 9' except for the mid wing which is 18'. I need the walls as shown below but the front and rear walls are one entity and the side walls are shooting up as 4" interior. It is almost the opposite of "lower wall type if split by butting roof". Suggestions? I am giving away upvotes left and right for advice. :D
image.thumb.png.8a86b7a14b699ce2d05990230cfd879b.pngimage.thumb.png.8b81a6969b44055df38a5ca893481b00.pngimage.thumb.png.ce91bda6ed62cbe0db7e3d5a9f95ba70.png
8 minutes ago, robdyck said:
Those walls should be your exterior wall type with the lower wall type set to use the interior wall (Roof> Lower Wall Type if Split by Butting Roof). Make sure balloon through ceiling above is checked for the side walls.
Worked Great Rob. And the front and rear walls were resolved when "pony wall" came to mind. All is good. Thanks.
