Not snapping to layer I want when doing point to point measuring
Jayne13
Hi TeaTime, Yes, that worked!  And what would be the layer to measure a part of the exterior wall assembly?  I would like to measure to the outside of the OSB, on the structural framing layer.  See attached for image description.788635078_Screenshot2023-08-10at11_50.37AM(2).thumb.png.d9cd3520a42f5c5f58ec72d5c93b36e8.png731486868_Screenshot2023-08-10at12_13.54PM(2).thumb.png.18fd4ae6970cf16d17ef86215999a8ea.png
Ah I think this is more about wall definition -- open that wall's definition and check it's layers and what groups they're in.
You'll only get snaps at the exterior surface, interior surface, and then the lines that separate construction groups: the lines between Exterior and Main Layers, and between Main and Interior Layers
Take this Brick-6 wall for example:
image.png.5f59c6f8bd139c5550a41592db3a5b55.pngimage.png.15c36defe9c07995adb6c293f16624ea.png
The only exception is Main Layer Center, but it won't snap to the Housewrap layer for example, or the outside of the OSB. I'd have to move the OSB into the Main Layers group to do that, and that can cause some issues elsewhere.
So in your example, if the Drywall, Service Cavity, and OSB were all in the Interior Layers then you should be able to locate it.
