SkullMesaRanch Posted August 10, 2023 Share Posted August 10, 2023 I'm not sure how this happened. I was working on the layout and noticed the eave is not right on 3 corners of the barn. The house is similar construction and the eaves are fine. It was only two corners not right on the barn and somehow I messed up a third corner. I should be able to select the attic wall and pull it to the edge of the eave but it doesn't work. I'm having trouble uploading the file and will try later. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 10, 2023 Share Posted August 10, 2023 It appears you may have selected " Flush Eave" rather than " Boxed Eave " in Roof Plane Specification > Options. Link to comment Share on other sites More sharing options...
SkullMesaRanch Posted August 10, 2023 Author Share Posted August 10, 2023 12 hours ago, Chopsaw said: It appears you may have selected " Flush Eave" rather than " Boxed Eave " in Roof Plane Specification > Options. I had boxed eaves checked. The problem was that the attic walls above the eave were 'pulled' into the overhang by mistake. Once I shorten the attic walls to line up with the structure walls (and rebuilt roof) it was fixed. As a side note this forum is incredible. 99% of the questions I have are answered quickly with a search. This forum (and software) has allowed me to design my own home/barn and I'm about 80% done with my construction docs. It's an incredible rewarding experience. Thanks to all who have helped! 1 Link to comment Share on other sites More sharing options...
