Drew-PRH Posted August 9, 2023 Share Posted August 9, 2023 I can not find any area within the door dialog for each door, the opportunity to specify if an interior door can be noted as Solid Core, and not All Interior Doors. Hmmmm. Can this be noted only on the Schedule under Comments? Thank you - Link to comment Share on other sites More sharing options...
Drew-PRH Posted August 9, 2023 Author Share Posted August 9, 2023 SOLVED - Comments Only under 'Object Information' from the door dialog. Which will then show up on Schedule Only, no other notations elsewhere. Link to comment Share on other sites More sharing options...
RobUSMC Posted August 10, 2023 Share Posted August 10, 2023 Add a custom field in the Object information 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 10, 2023 Share Posted August 10, 2023 I just add an s.c. to the label of exterior doors and a h.c. to the interior door's labels. This is in my template plan, so I do it once and it's always there.. Link to comment Share on other sites More sharing options...
