Linear Repeating Molding OffScale
kwhitt
I am attempting to create a piece of dentil molding.  I've model the simple shape at the correct scale (even the dialog window confirms the size is correct).  When I go to use the dentil, it comes in WAY oversized as show in the image below.  The poly molding line is 24" square and I am only able to show one LARGE repeat of the molding.  Admittedly, I can adjust the size in the molding dialog box and change the repeat; however, I am unable to change the depth to 1/4" which is the appropriate depth.  I have attached the CALIBZ file too.  Is this another glitch since the update?  If not, what am I doing wrong?  Thanks, Kevin
dentil.calibz
2 hours ago, solver said:
X15 seems to work if the molding is drawn in plan, but not elevation.
I tried X12 drawing in elevation and imported into X15 and it works.
Seems like a bug.
Thanks Eric.  I'll give it a try.  I would never have thought that would affect it.
Seems like a bug.
I tried creating it in plan view (btw - it was drawn in another program before and imported) and it still doesn't work.  It becomes oversized.  I tried stacking it with other molding profiles and the shape becomes skewed no matter what I enter for width, length, repeat.  It did come in oversized the first time and I had to adjust it down.  Definitely something off here.  I will report this too.
Eric - is it even possible to go back to the last version of X15?  A download somewhere?
Sure, all you need is the .msi file. Do you know
what release number you want? I have the fallowing
numbers in stock:
25.0.2.58
25.0.2.65
25.0.3.69
25.1.0.45
25.2.0.53
25.3.0.77
BTW, The files are like 300MB so getting it to you
could be an issue.
numbers in stock:
25.0.2.58
25.0.2.65
25.0.3.69
25.1.0.45
25.2.0.53
25.3.0.77
could be an issue.
Thanks Rich.  I just PM'ed you with an upload link.  Kevin
