Foundation bearing pads for point loads, etc.
someguy
Go to solution Solved by rgardner,
How do you usually do foundation pads for bearing points, etc. It seems strange they have to be under a wall. Is there something I am missing or a better way to do it?
I tried placing a square pad in the foundation and it only allows it under a wall.
It'd be nice to place it on the framing layer so it lines up with a beam or girder then copy paste in place to the foundation layer.
  • Solution
If not under a wall then you would need solid framing down to a pad.  Kind of like the "Post w/ Footing" tool...
