MicaGlassDesigns Posted July 3, 2023 Share Posted July 3, 2023 Hi everyone! I'm working on a large project and using barn doors for shower doors. Is there a way to shorten the barn door track so it doesn't protrude through the adjacent wall? If not, is there a better way to go about this altogether? I'm using Chief Architect Premier X15. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 3, 2023 Share Posted July 3, 2023 I think I remember having one that was too short one time and had to make the track into a separate symbol so that I could control the length. Now the library has separate components so you can place them independent of the door and size them accordingly. Link to comment Share on other sites More sharing options...
rgardner Posted July 4, 2023 Share Posted July 4, 2023 4 hours ago, MicaGlassDesigns said: Hi everyone! I'm working on a large project and using barn doors for shower doors. Is there a way to shorten the barn door track so it doesn't protrude through the adjacent wall? If not, is there a better way to go about this altogether? I'm using Chief Architect Premier X15. Just keep in mind if there is not room for the track then there is not room for the door to slide open on the track… Link to comment Share on other sites More sharing options...
Chopsaw Posted July 4, 2023 Share Posted July 4, 2023 11 minutes ago, rgardner said: Just keep in mind if there is not room for the track then there is not room for the door to slide open on the track… Good point Ryan. I guess I should have a disclaimer on my example " for display purposes only". Link to comment Share on other sites More sharing options...
