Change Existing Walls To Wall Type In Library
MickeyToo
Just add the lib. wall to the plan, then select all the walls you want to change, and go to your wall DBX, and the wall you added from the lib will be in that DBX to select from. Any wall you put on the plan will automatically add it to the wall DBX.
